Grue camion Palfinger RC4WD 1/10 - 1/14
Il est indiquer 1/14 mais trop gros pour le camion Tamiya.
Ce serais l'idéal pour un camion 1/10.
1/14 Truck Mounted Hydraulic Crane
Your Price:$1,399.99
Lien RC4wd
Spécifications:
CNC Machined
Black, Silver and Red Anodized Finishes
Aluminum Alloy Construction
Operating Voltage: 11.1-12.4V
40A Brushless ESC
Maximum Lifting Force:
3KG / 6.6lb Maximum for the Longest Arm
3.8KG / 8.4lb Maximum After Folding the 6th Section of the Arm
4.8KG / 10.6lb Maximum After Folding the 5th Section of the Arm
6KG / 13.2lb Maximum After Folding the 4th Section of the Arm
Height after Folding: 11.8in / 300mm
Width of Front Feet: 7.5in / 190mm (Folded) 29.5in / 750mm (Extended)
Width of Rear Feet: 7.5in / 190mm (Folded) 16.3in / 415mm (Extended)
Maximum Lifting Radius: 35.4in / 900mm
Maximum Lifting Height: 742.91in / 1090mm
Hydraulic Pump: Power Flow 0.8L / MIN, Rate Pressure 2.5MPA
Total Weight: 176.4oz / 5000g (Including Packing Material)
Lien RC4wd
Spécifications:
CNC Machined
40A Brushless ESC
Re: Grue camion Palfinger RC4WD 1/10 - 1/14
superbe
ça irait pile poil sur mon 8x8
mais va falloir économiser un peu
Bourineur- Messages : 10
» Vends pont arrière pour camion CROSS-RC
» [Sketchup SKP] Boite de vitesse 3 speed Tamiya camion.
» [Vend] Je vends tout, ou presque.... traxxas trx4, trx6, stampede, camion 8x8, remorque, etc
» RC4WD 1/24 Trail Finder 2 Mojave RTR
» NOUVEAUTÉS. RC4WD
» NOUVEAUTÉS. RC4WD
