Proto Crawler Home made V.3 - 2010
Proto Crawler Home made V.3 - 2010 Empty Proto Crawler Home made V.3 - 2010
Message  Nicolas le Dim 6 Aoû - 19:31
Donc voici la version 3 de mon Crawler Full Inox.
Cette fois çi adieux les vis sans fin, place au couple conique bien plus costaud et surtout bien plus mécanique.
Donc toujours la même donneuse (Thunder Tiger SSR ou SSK) :
Proto Crawler Home made V.3 - 2010 001
En plus de ses pivots, elle a aussi donner pour ce proto ses deux différentiels et ses cardans.
Proto Crawler Home made V.3 - 2010 002
Proto Crawler Home made V.3 - 2010 003
Proto Crawler Home made V.3 - 2010 004
Proto Crawler Home made V.3 - 2010 005
Proto Crawler Home made V.3 - 2010 006
Proto Crawler Home made V.3 - 2010 007
Proto Crawler Home made V.3 - 2010 008
Proto Crawler Home made V.3 - 2010 009
Proto Crawler Home made V.3 - 2010 010
Proto Crawler Home made V.3 - 2010 011
Proto Crawler Home made V.3 - 2010 012
Proto Crawler Home made V.3 - 2010 013
Proto Crawler Home made V.3 - 2010 014
Proto Crawler Home made V.3 - 2010 015
Proto Crawler Home made V.3 - 2010 016
Proto Crawler Home made V.3 - 2010 017
Proto Crawler Home made V.3 - 2010 018
Proto Crawler Home made V.3 - 2010 019
Proto Crawler Home made V.3 - 2010 020
Proto Crawler Home made V.3 - 2010 021
Proto Crawler Home made V.3 - 2010 022
Proto Crawler Home made V.3 - 2010 023
Proto Crawler Home made V.3 - 2010 024
Proto Crawler Home made V.3 - 2010 025
Proto Crawler Home made V.3 - 2010 026
Proto Crawler Home made V.3 - 2010 027
Proto Crawler Home made V.3 - 2010 028
Proto Crawler Home made V.3 - 2010 029
Proto Crawler Home made V.3 - 2010 030
Proto Crawler Home made V.3 - 2010 031
Proto Crawler Home made V.3 - 2010 032
Proto Crawler Home made V.3 - 2010 033
Proto Crawler Home made V.3 - 2010 034
Proto Crawler Home made V.3 - 2010 035
Proto Crawler Home made V.3 - 2010 036
Proto Crawler Home made V.3 - 2010 037
Proto Crawler Home made V.3 - 2010 038
Empattement : 335 mm
Largeur : 285 mm
Hauteur sous châssis/pont : 63 mm (avec pneus Hammer)
Poids châssis nu : 940 Gr.
Poids roulant : 3,10 Kg
la carro :
Proto Crawler Home made V.3 - 2010 039
Proto Crawler Home made V.3 - 2010 040
Proto Crawler Home made V.3 - 2010 041
L'intérieur avec quelques aménagements.
Des renforts, des supports et le fameux blocage du pont avant :
Proto Crawler Home made V.3 - 2010 042
Proto Crawler Home made V.3 - 2010 043
Proto Crawler Home made V.3 - 2010 044
Proto Crawler Home made V.3 - 2010 045
Proto Crawler Home made V.3 - 2010 046
Proto Crawler Home made V.3 - 2010 047
Proto Crawler Home made V.3 - 2010 048
Passage d'obstacle le pont bloquer droit :
Proto Crawler Home made V.3 - 2010 049
Le même passage débloquer :
Proto Crawler Home made V.3 - 2010 050
Pont bloquer a droite et a gauche :
Proto Crawler Home made V.3 - 2010 051
Proto Crawler Home made V.3 - 2010 052
Le déblocage peut ce faire en tension (roue en l'air)
Par contre c'est n'est qu'un blocage, je ne peut pas placé le pont comme je veut, il faut anticipé .
Le poids total est maintenant de 3.6 Kg.
Proto Crawler Home made V.3 - 2010 053
Proto Crawler Home made V.3 - 2010 054
Proto Crawler Home made V.3 - 2010 055
Proto Crawler Home made V.3 - 2010 056
Proto Crawler Home made V.3 - 2010 057
Proto Crawler Home made V.3 - 2010 058
Proto Crawler Home made V.3 - 2010 059
Proto Crawler Home made V.3 - 2010 060
Proto Crawler Home made V.3 - 2010 061
Proto Crawler Home made V.3 - 2010 062
Proto Crawler Home made V.3 - 2010 063
Proto Crawler Home made V.3 - 2010 064
Proto Crawler Home made V.3 - 2010 065
Proto Crawler Home made V.3 - 2010 066
Proto Crawler Home made V.3 - 2010 067
Proto Crawler Home made V.3 - 2010 068
Proto Crawler Home made V.3 - 2010 069
Proto Crawler Home made V.3 - 2010 356124158
Proto Crawler Home made V.3 - 2010 Empty Re: Proto Crawler Home made V.3 - 2010
Message  Chris Customs le Lun 7 Aoû - 22:06
Sympa cette astuce.
Proto Crawler Home made V.3 - 2010 3069634564
Proto Crawler Home made V.3 - 2010 17022602200022653814876012          Proto Crawler Home made V.3 - 2010 17111110212422653815365363       Proto Crawler Home made V.3 - 2010 17111109474722653815365335
Chris Customs
Chris Customs
http://scalesandcrawlers.forumactif.org/
Message  Nicolas le Mar 8 Aoû - 18:16
Oui, simple et efficace.
Je vient de le remettre en état. Lors de la dernière sortie j'avais casser un des cardans avant.
Maintenant ça va etre plus solide avec des CVD a la place des croisillons.
Faudrait que je refasse un tour avec, ça fait longtemps qu'il prend la poussière.
Message  Nicolas le Dim 13 Aoû - 19:45
J'ai refait une sortie de test.
Le moteur 85t était brulant au bout d'une demi heure de crawling asser hard.
J'ai commandé une platine pour mettre deux moteurs et j'ai aussi pris deux 55t neuf.
Puis ensuite si ca va pas je passerais avec deux moteur 80t.
Malgré le moteur faiblard ça fait plaisir de refaire du crawler, ca grimpe étonnamment bien.
Je crois que je vais me refaire un AX10.
Proto Crawler Home made V.3 - 2010 1025284884
Message  Corleone le Jeu 31 Aoû - 16:05
Et alors ça donne quoi maintenant ton truc en fer ?
Message  Nicolas le Jeu 31 Aoû - 23:29
Pas encore reçu les moteurs, patience .......
Message  tetrix le Sam 2 Sep - 2:39
je ne comprend pas a quoi sert le truc a trous ?
et je voie sur une des photo un train électrique tu est amateur ? je cherche à vendre le miens si jamais
tetrix
Message  Nicolas le Sam 2 Sep - 12:28
Le truc a trou sert a bloquer le pivotement du train avant.
Il peut ainsi ce bloquer dans la position que je veut grace au multiple trous.
Pour le train je n'ai malheureusement plus de place.
Le circuit a été démonter et les trains stocker au grenier depuis l'arrivé de bébé.
La chambre a train est devenu sa chambre.
Message  tetrix le Sam 2 Sep - 22:48
tu vas nous faire une petite vidéo? j'aimerai voir ton truc en fonctionnement
tetrix
Message  Nicolas le Dim 3 Sep - 15:11
tetrix a écrit:tu vas nous faire une petite vidéo? j'aimerai voir ton truc en fonctionnement
Promis, dès que j'ai changer les moteurs et trouver un moment je fait ça.
Proto Crawler Home made V.3 - 2010 3396141370
Message  tetrix le Lun 4 Sep - 1:36
cool merci Proto Crawler Home made V.3 - 2010 1025284884
tetrix
